Prop Advice
bassone
I have a 99 triton 180 premier that has a Johnson 115 spl that went bad so i just purchased a Evinrude 150hp to replace it, came without a prop so could someone please help on what prop i should start with, thanks for your help
Re: Prop Advice
Ayuh,... Put yer old prop on, 'n try it to get some baseline numbers...
Sprky
Re: Prop Advice
A 24p 3 blade of some flavor should be real close. If you run light and maximize your set-up, maybe a 25/26
