prop application given hub number
hooks1
I have a pleasant puzzle to solve: Bought an old river cabin and in cleaning up I found a nearly new SS prop probably from 1995 to 2005. I forgot to bring it home so I can't post the number on the hub for a few days but I wondered if there is some sort of master cross reference list to find out what it fits. Right now all I know is it is a three blade RH 14 inch (may be 19 pitch - don't recall) and has a splined hub but it is a smaller spline diameter than my MC Alpha one (darn!). What is the likelihood that I can find some person or group that would trade for one I could use? It is so much heavier than my aluminum prop I can understand why they are more durable.
Thanks
Don
extreme76
Re: prop application given hub number
Once you have the number(s) from the prop you can try to search here.
http://boatpropellers.iboats.com/?*******=850886013&**********=865477729
Look up by prop number.
Otherwise post it and someone might be able to help.
Trade it? I don't know I suppose if you found the right person. I would guess you could probably sell it on ebay etc... but it will depend on what it is and condition as far as price etc...
hooks1
Thanks - I'll have the number tomorrow evening and post if I can't find the application through the part number route.
hooks1
Mystery solved - partially
The mystery prop (#389948) is a 13 3/4 inch X 17 pitch with a 13 tooth spline and appears to fit Johnson and Evinrude OBs and some OMC stern drives. It is a Britt brand and I haven't yet researched that. Thanks for the help.
update: It is a reworked Michigan Wheel prop and it is actually 13 3/8 diameter and not 13 3/4 (mis-read). Turns out Britts is a prop shop near Mobile, AL that must have cleaned it up and stamped it.
WIMUSKY
Post up some pics......
