prop barrel ?'s
MBAKER
A few prop questions...
Some aluminum props have a raised 'wedge' ( for lack of a better term) on the barrel around each blade some dont, I dont think ive ever seen them on stainless props. What is the purpose of this raised area?
What does the lenght of the barrel affect on a prop? I have seen some props that have a longer barrel than others, and have seen talk about cutting the barrel shorter to tune the prop.
Frank Acampora
Re: prop barrel ?'s
I think the term you are referring to is a "Flare." It is there to modify water flow and contain exhaust, especially in reverse when exhaust would foul the prop blades. A longer straight hub will have the same effect. OMC used to have a ring around the outside of the hub but I believe newer models have discontinued this. Suffice to say: The manufacturer has tested the designs and incorporated that feature which will give best over-all performance.
MBAKER
Re: prop barrel ?'s
I should clarify, the wedge I was talking about is on the side of the barrel at the base of the blade, not the flare on the end. Its like a raised portion of the casting around the base of the blade.
Frank Acampora
Re: prop barrel ?'s
Stainless props are cast by lost wax process and the mold is a single friable piece that is sand blasted off after cooling. THUS: no excess metal is necessary.
Some aluminum props are cast with a re-usable three piece mold and the wedge is there so the mold can be removed after cooling. The wedge serves no purpose and does not either enhance or decrease performance.
jerryjerry05
Re: prop barrel ?'s
I believe the extra metal is there for strength.
Like adding a boss under a screw or bolt.
It helps to strengthen the base so the blades don't twist off under acceleration.
