Prop Change Questions.
Status
Not open for further replies.
Harritwo
I have a 94 Sea Ray 170 Signature Series with a 3.0L Mercruiser, Alpha 1 Gen II outdrive, currently propped with a 14-1/2" dia 19 Pitch Alum 3 blade prop. WOT is 4400 RPM's and 34 MPH by GPS. I wish to change props to a Solas 4 Blade in the hopes of increased performance and maybe speed. When going to a 4 blade, will pitch and diameter remain the same for WOT or which way should i go on pitch and diameter. IBoats is having a sale on the Solas and this would be a good time to buy for me. Any help, thoughts, recommendations are greatly appreciated.
George
Chris1956
Re: Prop Change Questions.
What is the max recommended RPM for that motor? I will bet you are at or close to it right now. If your current prop is damaged, a new one will give better performance, however, if it is not damaged, the change will have little effect.
Are you trimming the OD to gain max speed?
Harritwo
WOT is 42-4600 RPM. No damage to prop, just wanting to increase performance/speed if possible and wanted a new/spare prop. I trim to obtain speed and ride as high on the water as i can without porposing.
Chris1956
Sounds like you have the correct prop already. I would stick with the same pitch.
Starcraft5834
"94 Sea Ray 170 Signature Series with a 3.0L Mercruiser, Alpha 1......"
Im not familiar with size of your boat, I can tell you I've got a 3.0L Alpha 1 on my 1987 20ft cuddy. I replaced my 3 blade prop with a 4 blade Solas 15p,, it's 14.75 dia (i think). I had to remove the fin anode and install a flat anode.. My observations on change are the following...
hole shot went from feeling like I was trying to pull a large appliance out of the water on plane, to with a 4 blade, up on plane in less than 5 seconds.. that's with 5 adults in boat too... Steering improved at slow speed a great deal with the 4 blade. Top end speed went down about 2 mph,, WOT 33mph 4500-4600 rmp with the 4 blade solas...... Make no mistake, I dont think anyone has ever increased top end speed by going to a 4 blade.. If you tube, water ski,, you want the 4 blade... period.. 4 blade is generally better in more areas than the 3 blade.. others may disagree.. those are my findings...
steelespike
My limited research indicates a lightly loaded 170 like 3.0 with a 21" pitch 3 bld. would struggle with a load or hole shot
but would run about 40ish. 19" often over revs if lightly loaded.
Check some simple things; does throttle open all the way? is the timing set right and advancing as it should
Bottom clean and smooth?Motor in excellent tune?
Status
