scot.mcpherson
- Aug 7, 2015
- 4
Hi,
I have a SeaSprite 23 sailboat, it dispaces 3350lbs at the water line. It was designed to hang a small outboard motor on the back. I have a 1963 Johnson Fisherman 6hp hanging on the back which pushes the boat along ok, but the propeller is a weedless 2 blade prop designed to push small fishing boats through the weeds.
I'd like to know what you think would be the best choice of new propeller for this engine to push this boat up to its rated hull speed, which is 5kts cruising and 5.4kts max hull speed. I am not trying to push the limits of making a displacement hull go faster than it's hull speed, but at present the engine pushes the hull at around 3.5-4kts, and and I wouldn't mind getting up to 5 kts.
Also since it's a weedless design, putting the motor in reverse yield abysmal results. Is just can't grab enough water to do anything worth while.
Do you folks have any recommendations for prop choice for my engine for the boat I have?
I was thinking of getting a 3 blade with reduced pitch, but not sure what the best choices in that realm are.
Thanks,
Scot
Thanks,
Scot
