full stringer
- Nov 8, 2009
- 184
ok i have a 350 chevey with a omc 800 stringer outdrive i just changed my omc outdrive upper from a v-8 gearing to a v-6 geared upper the old unit had 21:16 ratio and the new upper has a 21:20 so is geared higher if you will i ran the boat today and with an aluminum 14 1/2 x 19p prop the engine is way over revving.its doing 3000 rpm and only 14 mph with the old set up a 15 x 15ballistic stainless prop and the other upper gearcase 21:16 it would run about 25 mph at 3100 rpms what size prop should i change to a shop said go up 2 inches well i went up 4 and still way to high rpms that motor will turn 5000 rpms right now if i throttled it wide open really need some help on this one??? the boat is a sea ray cruiser weighs 4020lbs dry weight
