cheaperts
- Feb 12, 2012
- 55
I have a 20' Lowe pontoon (2 logs) with an 89 40 hp Johnson on it. Motor runs well but is getting kinda tired, I want to repower it with a 70 hp looper but till the right one comes along we will putt along with the 40 horse.
A week ago we spun the old prop that was on it, it was a 3 blade Michigan 12.5x13p. Boat does not have a tach but I have never felt it was getting 5000 rpm, boat on a good day would get 12 mph on gps, usually around 10 mph.
After researching here and elsewhere I decided that I would do better with a 4 blade and less pitch. I found a bargain on ebay for an 11.5X10p. Put it on tonight and took a test drive, boat actually seems much smoother accelerating, but top end is less and f I open it full throttle the engine actually has surge, never did that with the bigger prop. If I pull the throttle back slightly it runs smooth but we are at 8-9 on the gps. Does the engine have a rev limiter that would cause it to surge? Any better recommendation on prop size/pitch/blade count?
Advice anyone?
Advice anyone?
