Prop diameter and pitch stamp incorrect
jfmining
Recently pick up a Michigan prop SMC 345. When I tried to figure out info on the prop I discovered that the prop stamp designates the prop size as 1820. The prop however measured diameter is 14.75" and the pitch calculates out as between 17 and 17-1/2. Was this prop just miss stamped or maybe resized if that is even possible. The prop looks new. Does anyone have any insights.
airshot
Might very well be reworked, a good propsmith will make it look like new, however those I have had reworked have always been restamped with correct info. So your could be anything...have it checked at a prop shop to be sure your numbers are correct
dingbat
Digging into this a bit, the SMC 345 (item # 082030) is advertised as a 15 x 17 prop.
Coincidence your 1820 matches 3 of the item numbers in sequence?
1960 Starflite
I have a couple props with no markings. May I ask "how did you calculate the pitch".
QBhoy
Looks like a fair old diameter from pics at least. What are you using this on, if you don’t mind me asking
jfmining
Thanks for the info. As you can tell I no little about props.
jfmining
