I have a 1996 Four Winns 170 Horizon with a 130 HP Johnson outdrive. Ratio 2.25 to 1. In most references I can find, the recommended prop size for this motor is a 13.5 inch diameter. As far as I can tell, it came from Four Winns with a 13.5 x 22 pitch (this is from the specs. published online by four winns..)
All three props that came with the boat when i bought it are 14.25" diameter, however. I can only assume that since the specifications for my boat call for a 13.5 x 22 that these 14.25s are aftermarket.
I have two 14.25 x 21 and one 14.25 x 19. Haven't run the 19 yet.
The spec for my boat say top speed should be in the 48 mph range, yet I can only get about 43 out of her, according to the pinwheel-style speedo readout on my fishfinder/depthfinder. This is with the 21 pitch.
This is at WOT at 5250 RPM, so I calculate about 9.3% slip with the 14.25 x 21 (if I did it right???)
I guess my question is twofold:
1.) If it is at 9.3% slip, is this good?
2.) what are the ramifications of going bigger diameter on my prop? 5,250 seems pretty low for WOT, I am wondering if the bigger prop is too much for it? I don't know much about prop diameters, so am hoping for some help/recommendations.
I don't know if the previous owner found the 14.25 to be a bunch better through tiral and error, or if he got a good deal on them and figured they'd work, you know? anyway, any insight you can lend would be appreciated.
The reason that I am asking is because i am looking to get a good stainless prop and want to get the right one...
