Prop Direction on 1999 Merc ELF 25 HP
bakerlh
I am going to install a transducer for a fishfinder and the instructions recommend one side of the transom if the Merc prop moves clockwise (as you view it from behind), and another side if it moves counterclockwise. I believe my prop rotates clockwise as viewed from behind. Can someone confirm?
GA_Boater
CW sounds good like 99.99999% of Merc OBs.
Look down at the prop and if the blades are like /, it's CW. \ is CCW.
