PROP FOR 1990 EVINRUDE
bcook204
Hi all, Could someone tell me what size prop is suggested for a 1990 Evinrude XP150 V6 VRO on a 1990 Ranger Commanche 361V? I would like to purchase a aluminum prop. Also what brand do you prefer?
bcook204
Yes, It is a Raker 394755. It says 14 1/2 x 24. But it looks like someone or manufacturer tried to cross out the 24 and stamped 23P on it. Looks professional that's why I said maybe its the manufacturer.
ondarvr
You need to use that prop as a baseline to determine what to get next, if anything. You need the correct RPMs and speed and see if this prop is close, then dial it in from there.
bcook204
The prop is stainless steel and 2 of the blades have a slight bend on the tips. I am going to have it repaired, but would also like to purchase an aluminum prop for a spare. I think I am going to stick with OEM part 394755. 14 1/2 x 24. But I can't find a aluminum prop that is 14 1/2 x 24. Also what company should I consider that is known for making a good quality aluminum prop.
