I have a 2003 25 hp Mercury 2-stroke (2.25 gear,5000-6000 rpm) on a 2002 Tracker pro crappie 175 the guy I got it from stripped the inside so it just has an open floor the motor is a tiller handle. I'm looking for prop so I can get in the upper end of my rpm range. Right now I'm running around 5200 rpm's (tiny tach) and 22 mph (gps) with lots of slip 20 some percent. The prop I have is a Mercury prop #QA2106R P13 10.38 inches.
This last weekend I built a jack plate and raised the motor 2 inches to get the motor closer to the proper height but with the added height and the prop I wasn't able to adjust the trim pin to the middle and have the prop still bite. So my numbers were around 5100 and 21 mph. The motor still needs to go higher I have water coming up the front of the motor but with the prop I don't think its possible to go higher and still have it bite in less its trimmed all the way down.
I would like to go to a SS prop is possible. Any ideas on props and pitches that would possibly work with my set up on an under powered boat. I'm not in a hurry so I'm not worried about going faster than the low 20s. Just would like to have less slip and proper end of the rpm range.
