Prop for 4.3 Bayliner, Alpha 1 Gen 2
mrsmith35sg
I have a 92 Bayliner 1850 with a 4.3 Mercruiser, Alpha 1 Gen 2
Its 17.5 to 18 ft. Gearing is 1.84
Recommended WOT is 4400-4800
Its a LH Rotation unit.
I don't currently have a prop. The boats been in storage at a family members and I have no clue where it went. I plan on having usually 2-4 people in the boat with a bit of gear, (a wakeboard and rope). My intent for the boat is general cruising, with a bit of watersports (tubing/wakeboarding)
I'm looking at a stainless steel prop. Most of what Ive gathered from other people with similar size boats have likes around 14" prop at 21 pitch. Any help would be great!
180shabah
Re: Prop for 4.3 Bayliner, Alpha 1 Gen 2
Unless you find someone with the exact same boat, loaded exactly the same way, with the exact same...... chosing a prop will just be a guess.
As far as that goes I think 21" pitch is a very good place to start for that setup.
FWIW - I have an 18' Mariah with a 4.3LX and same gear ratio and can turn a 14 3/4 X 21 Hustler a;; the way to 48oo RPM with normal load.
mrsmith35sg
Thanks for the help 180.
I had found a sst prop in good shape for 100 so i wanted to get the best idea i could before i went with the 14 21p prop,
