DukesFin
- Oct 12, 2005
- 502
I've got a '74 Grady White 212 Chesapeake. Running it is a GM L6 250cid (165hp) and an OMC Stringer Elec. Shift outdrive...
Right now, I've got a 19pitch prop on it and while on the water, I am only able to get my RPM up to 3000 and speed (on the GPS) is 33.4mph.
I know my engine can turn faster @ WOT as it did before I put this used lower unit on (and the prop I am running came with the lower unit). My old prop is so old that I can't read the pitch on it, but apparently, the pitch was not as high as 19.
The speed I can get to right now is fine, but I use my boat in the Gulf of Mexico a lot and want to be sure I can run from a storm quickly if I need to.
Any help is GREATLY appreciated!
