Prop for Sea ray 205 Sport
EWU SWOOP
Good evening - I have been looking all over and need some help selecting the best prop for my Sea ray 205 Sport. I have the 5.0MPI and will be using the boat for pulling wake boards, tubes, and just having fun on the lake. Thanks.
steelespike
We need some lightly loaded wot(wide open throttle) rpm , gps speed and prop size,usually found under the prop nut.
also need the age of the Sea Ray.
Scott06
I would echo the questions above, but most likely you'll have a19" or 21" 3 blade on there? 19" would definitely give better holes shot, if you really want more holeshot for tubing, wakeboard etc try going down to 17". If your willing to give up a few mph on top end a 4 blade in 18" (16" if you really want holeshot only) like a Michigan vortex would probably give good performance where you are planning to use the boat
