Prop gone missing VP280 1977 Volvo
Old & In the way
Hi
Had my 1977 Glastron Tri-Hull T179, VP AQ130D at the shop for months, now shop doesn't answer - towed the boat home - prop gone missing.
Pls. help with your best guess to replace the prop. Seloc only talks in generalities on this one.
The shaft is about 4" with about 2 and 1/4" grooved. The cone is a screw-on with a metal washer with slots that fit into the cone. cira 1977.
As I recall the diameter was kinda large - about the size of a medium pizza.
1) What prop ?
2) Do I need a special tool to mount the prop ?
3) Should I pay to have it done, or can I do it ?
Thanks.
Ed
captmello
Re: Prop gone missing VP280 1977 Volvo
Most volvo oem props are 14" Diam, that drive can handle up to a 16" i believe. Not sure which pitch however. 17-19 I suppose. BTW that is a short shaft lower 4" hub like you said. screw the cone with the tabbed washer in front, snug it down with a screwdriver through the cone, bend over the tabs on the washer.
Could ask over in the prop forum. Large loads, waterskiing, may want 15-17pitch, two-three people cruising 17-19 pitch. Very hard to determine without trying. I think you can get an aftermarket prop right here on Iboats for $100+.
Good Luck!
hwsiii
Old, how much does your boat weigh and what is the gear ratio for the outdrive.
H
Old & In the way
H
Don't know the gear ratio.
The boat is just a 17 foot tri-hull.
Should I move this to the prop forum ?
Ed
Old & In the way
Ed
Some one moved it to the correct forum. Thx.
The boat is a 17 foot tri-hull, VP 4 cyl. 130hp. 1 or 2 passengers.
Thanks.
Ed
hwsiii
Ed, I show an allup boat weight of right at 2,400 pounds and the motor to be 130 HP with a 2.15 gear ratio. If all of that is right my program shows you need an 18" pitch prop.
H
