Prop Hardware
stnick
Bravo 2, 1993 Searay Sundancer 290, 7.4l
I have purchased a stainless prop to replace the aluminum. Do I use the same thrust washer, locking ring, nut etc or do I need additional hardware?
Thanks guys!
Nick
Re: Prop Hardware
Thanks guys!
Nick
Ayuh,... If ya got 'em both,... Try the pieces on the prop hub,.... Do they fit, or not...
BIIs are a breed of their own,.... I'm not sure....
Are the props Merc props,..??
stnick
Re: Prop Hardware
Yes, both Merc props. Bravo 2 is new to me. I used to run a stainless chopper on Alpha one and it used it's own thrust washer, thats why I'm asking first. My Bravo 2 boat is a chore to change props due to it being in a slip and the prop only raises to about 10 inches below the surface. Wanted to have everything on hand before I go over to marina.
Thanks,
Nick
