bassndude112
- Jul 15, 2003
- 8
Hi,<br /><br />I'd like to increase my top speed. Currently I'm barely getting up to plane (19mph) on my 15ft smokercraft aluminum (1000lbs gross). The recommended rpm is 5500-6000 and I'm at about 6000 rpm WOT on a 10 7/8 x 11" prop. <br /><br />Through reading eariler posts, I found that I could go up to 2" to a 13" prop. However, after using mercury marines prop selector, it recommended that I should use a 10 1/8 x 15". <br /><br />My question is can I really go up to a 15" and if so is this because of the smaller diameter? Or should I just go with a 13" ? I'd appreciate any opinions on this. <br /><br />Thanks,<br />Sunny
