Just got a new Lowe model 175 Aluminum hull. Length is 17' 5".. Weight of Hull is 1110. Capacity weight is 1010. Width is 85" Transom Height is 20" Powered by 2006 25 horse 4 stroke EFI. Model F25ELPT. Maximum RPM 6000. Prop is 9.75 diameter X 9.5 pitch (48-896892A40). Prop has 10 splines and is aluminum. I know this is a lot of boat for the small motor and I don't expect to set the water on fire. I'm just trying to get the best performance possible and the dealer has been very little help. Problem is that the boat comes on plane very slowly and actually does'nt ever come fully on plane. At 3/4 plane (nose is still up) boat will run about 12 mph. I could care less how fast it goes but am determined to get it to plane better. Dealer says no SS prop exists yet to replace this prop and can only suggest a hydrofoil. Before I start drilling holes in my new motor, I would appreciate any input as to the most effective hydrofoil and opinions on whether this will help. I have heard good things about the Stingray but the horsepower spread starts at 25 hp and goes to 140 hp. Would this be too big or should I try the Stingray Jr. for smaller motors. Would a 4 blade be the answer? Are there any suggestions for prop changes that might help? Thanks in advance for any advice!!!!
