onchoryncus
- Apr 5, 2009
- 3
I have a 19' Arima Sea Chaser (walk around cuddy). Normal operating boat weight is around 2800 lbs, ie: hull, people, motors, fuel, gear, ect....
Currently I am running a stock 14"x19Px3BL aluminum prop at 6300 WOT on a 2008 DF140. The boat planes easily but the prop feels like it isn't holding as well as it should at cruise, then breaks loose on accelleration. Top speed is good at 37-39 mph depending on currents/tides. I am looking for more lift and grip for better cruise performance and would like to at least keep my top speed.
Also.....I tried a Powertech PTR 13.5"x18Px4BL and it pushed the rev limiter at 6600 rpms and 400 rpms over the recomended range. The prop just wasn't enough dia for the motor and would break loose on all accellerations and it gave the same or worse slip numbers than the stock aluminum 3 blade????
Any help would be appreciated!
Thanks, Shane
Thanks, Shane
