waltherbey
- May 16, 2005
- 11
I'm looking for some suggestions...<br />I just got back from a test run with my current prop and I recorded a speed of 50MPH on the GPS. One person 1/2 tank of gas.<br /><br />Sounds good enough right? <br />But that was with no trim adjustments because I was already bouncing off of the rev-limiter at about 5000RPM. I never hit WOT.<br />My current set-up:<br />19' Bayliner<br />4.3 MPI 220HP<br />Alpha 1 1.81 drive ratio<br />Dry Weight = 2750<br />14 X 23 Aluminum prop<br /><br />Average weight during family outings = 3400<br /><br />I use the boat for tubbing, and skiing mostly so I would like to keep a good hole shot. I was thinking about going to a HighFive 24 or 25 pitch. Will this help me get my WOT back in a reasonable range while not losing too much low end grunt?<br /><br />I need a spare prop regardless so I am open to any suggestions...
