Prop help
JLobell
I have a triton tr186 dc with 175 optimax running a 24 pitch tempest
Hitting my rev limiter still have 23 lbs water pressure can't run wide open due to rpm. Bigger prop come up on my motor? Right now I still have a good hole shot.
steelespike
Re: Prop help
Not sure what your asking; props up to 28" pitch are available here at iboats.
JLobell
Re: Prop help
Basically I want to be able to run as fast as possible, and just wanting some opinions. If I run a bigger prop that should take care of my rpm problem and with 23 lbs of water pressure I should be able to come up on my motor some? Looking for some suggestions
steelespike
Re: Prop help
at what rpm does the rev limiter cut in? What is the speed?What is the max rated rpm?
Raise the motor till just before you lose water pressure and or get ventilation problems.
Dhadley
Re: Prop help
We have had great success with the Turbo Fusion 4 on those hulls.
