Prop Help!
samjk10
I have a OMC Cobra 5.0L engine in a 1994/5 (unsure specifically what year) Four Winns Horizon 19' open bow. I am searching for a prop as mine has been damaged. Looking for a 14.25x21 MI Wheel BU433 505Z three blade aluminum prop. I am having the hardest time finding the right prop.
The prop sits on a brass washer, slides over the shaft, has a black almost tube like insert that is put down the tip to fit snug between the prop and the shaft, then is capped off with a nut, nut cover to lock in the pin. My current damaged prop does not have a rubber bushing.
I have been unsuccessful in finding this prop and would greatly appreciate some help!
Scott06
Search michigan vortex 3 blade # 99205 you may not find that exact michigan prop you currently have but this is an equivalent that will work with the modern plastic hubs
