prop ID help
rguy
I've got a 1988 Force 85HP with single exhaust. I need to buy a prop with more pitch, but I can't tell what I've got. These are the only numbers I've found on it but none will decode...
K5359
523282
0413
Thanks.
Rob
jerryjerry05
Re: prop ID help
If the prop is original. Then someplace on the prop close to the blades.They usually have a # stamped in there.It will be a 15 or 17 or 19 stampped in there someplace. What RPM are you running at WOT?J
rguy
Re: prop ID help
Those are the only numbers I could find. The engine will exceed 6k if I put the hammer down but I keep it down to about 4.5 to 5k.
Thanks.
Rob
jerryjerry05
Re: prop ID help
Does it say what kind of prop? Any names? How about a few pics.Hub included.J
rguy
Re: prop ID help
I dropped the prop off at a local marine shop and they could determine the pitch.
The only thing I can tell is that it has 3 blades and it is approx. 13.5" in diameter.
If I can't figure this one out, can someone recommend a prop. This is for a 1995 20' Pontoon boat with a 1988 Force 85hp. I want to keep the maximum RPMs about 5 to 5.3K.
Thanks.
Rob
