brooksville_rebel
- Aug 12, 2011
- 240
I finally got my prop off and after some vinegar soaking was able to get the info on the stamps to be read.
The prop says on one side
F 12.5 x 8 P
AF
L
The other side says
12
A
Now at the Mercury site when I did the prop selection tool it said I should be looking at for
aluminum Black Max 12.25 " 3 blade 9.0 pitch RH rotation.
I assume the L on the old prop means Left hand rotation. So does that mean the prop is wrong rotation or was on backwards (if possible) ? How do you tell which way the prop was spinning or is spinning while on the lower end ?
So little confused on what I should be looking for in the prop specs.
F 12.5 x 8 P
AF
L
The other side says
12
A
