Re: Prop keeps turning on 40 horse
If you are on muffs, and going from forward or reverse to neutral, the prop will still spin for a little bit until friction overcomes the acceleration and slows it down. My prop naturally spins when in neutral, but not enough to propel the boat. I also found that I had to kind of make my own mark in order to set the shift linkage where the controls would work properly.
