My current prop has been on the boat since I bought it used. I rarely run it at WOT. I usually cruise out to my fishing spot at about 30 mph and anchor most of the day, or troll at very low speeds. Have used it a couple seasons to pull kids in a tube on kneeboard, and the fastest I would pull them is about 15 mph.
Just recently started reading this forum and the importance of having a prop to match mfr's recommended WOT range. And I've found out over the last few times I've taken the boat out that at WOT, I'm at least 300 rpm under the recommended range.
I would like the recommendation of the many prop experts here to help me chose a brand and the proper pitch for my boat.
1978 Caravelle, 17' bowrider, 82" beam, 2000 lbs dry weight
used mainly for fishing
12 degree deadrise
1978 GM Inline 6, 165 hp motor, drive gear ratio 1.65:1
Max RPM at WOT: 3900-4300
current prop: 15 1/2", 19 pitch aluminum, good shape, minor nicks
Normally 2 people on board with 14 gallons gas, 2 batteries, fishing gear, 2 ice chests. My WOT RPM is approx 3600 RPMs, GPS speed approx 36 mph, elevation: sea level and up to 550 ft.
I'm thinking I have to go to a 17 pitch to get me in the proper WOT RPM range. I checked the iBoats store and there are several to choose from. Any advice/recommendations on brand and pitch would be appreciated.
Lastly, how would this change in pitch affect my cruising speed and fuel usage?
12 degree deadrise
