2008 lund classic 1660 side console
16' 6"
900+ lbs dry weight
60hp mercury 4 stroke efi (not bigfoot)
WOT range 5500 to 6000 rpm
the mercury aluminum 3 blade prop from the dealer was 10 3/8 inch diameter 13" pitch
with dealer prop WOT was 6100 @ 36 mph
The problem was getting on plane with more than 2 people in hte boat. The rear end would squat, and it would take forever to plane unless we moved someone to the front of the boat.
I decided to try a 4 blade prop to get better hole shot and stay on plane better at lower speed. I read that you should drop 1 inch in pitch when moving to a 4 blade, but snce I was a bit over the max rpm, I decided to try the Solas 4 blade aluminum at the same pitch. The new prop is 10 1/2" inces in diameter, and the pitch is still 13.
I was expecting a 200 to 300 rpm drop since I didn't drop down in pitch, however with the new prop WOT is only 5400 rpm but I only lost 2 mph to 34 mph. WOT rpm is not even in the recommended range now. What did I do wrong? Is one of the props not at the specified pitch? It seems odd to lose 700 rpm and only drop 2 mph. Can I measure the pitch somehow to see if I got the right prop?
Will the 12" pitch 10 4/5" diameter Solas 4 blade aluminum prop put me in the correct range? Are there better alternatives?
Are there alternatives to buying another new prop? For example could the new 4 blade prop be adjusted at a prop shop to a lower pitch, or would I be better off buying another new one? Any idea what prop shops charge for that type of work?
Other suggestions?
thanks in advance
16' 6"
900+ lbs dry weight
Other suggestions?
thanks in advance
