Prop not spinning
Dominic123
Hey guys, currently have twin stern drive mercruiser 350 mag mpi.
Was cruising at 1600rpm and suddenly felt a loud thump while trying to accelerate. Prop on the right engine is not spinning and won’t engage into forward or reverse gear. Any thoughts would be helpful. Thanks in advance
ThomW
Need a little bit more info. You felt a loud thump? Like you hit something with the prop/lower unit?
When you say it won't engage into F/R, do you mean you can't move the shifter into gear...or that when you shift into gear, that engine just revs and the prop isn't spinning?
Dominic123
Did not feel like I hit something with the prop, felt more like built up pressure had caused something to pop off as I was accelerating.
When I engage into F/R with shifter while engine is running nothing seems to be happening or turning.
Although I did manage to lift the right engine up the leg feels a bit loose as I can lift it up and down as well as right to left.
ThomW
Have you checked the shift cable to that engine to see if it may have snapped?
Dominic123
Update: leg feels majorly loose as i manage to lift it up and down easily. Not sure if this can be from bad hydraulics ?
Check the gear oil.--Post what you find.----Universal joint failed ?-----Perhaps coupling spline failed.
Dominic123
Does have gear oil as far as I’m concerned. Boat was lifted out of the water last week to service legs. Could mechanic possible not have assembled something correctly ?
ThomW
When you put it into forward or reverse, can you spin the prop with your hand...or does the prop spin freely?
Dominic123
Spins freely
Serviced last week ???-----Call the mechanic to come and check it.
that is hopefully the plan, just found it out of the ordinary how this could happen without any minor signals of something going wrong. Looks like the drive shaft has possible come out of alignment ?
QBhoy
Is this a bravo one or 2 ? They have different prop hub arrangements
could be coupling, could be drive shaft, could be gears, could be u-joints, could be something messed up during the work that was done
pull the boat and start investigating
trim hydraulics have nothing to do with driveline
Spins freely
failures happen without warning
driveshafts dont instantly come out of alignment. they do require an annual inspection of alignment as part of the annual service.
Dominic123
The legs were serviced last week, had a jump in the water and the lower unit was moving much more freely than usual. Almost seems like it has completely come loose, had even double checked with the left legs and they not wiggle around at all
and its broken now.
time to pull it back out
