prop numbers
jarviswb
i have a 115 horse mercury motor and i thought about buying a new prop cause mine is chewed up pretty bad what would be a good prop to use for performance and where would i find the numbers on it for an upgrade or to buy the same prop
Spidybot
Re: prop numbers
We need to know more about the parameters that affects prop choise:<br /><br />Boat make and model, weight (ready-to-go), width and how you use it? What kind of sea bottom is there at you normal sailing area?<br />Motor: Year, what rpm do you reach at WOT, what size/number is on the old prop?<br /><br />Upgrade: What are you looking for? Top speed or hole shot?<br /><br />Budget: Stainless is 2-4 times the price of alu or composite (roughly). What is your preference?
jarviswb
Re: prop numbers
its a 17 1/2 thompson dont know the weight guessing about 2500 lbs 20 gallon fuel tank the problem is i dont know the size of prop its a early 70s boat i would like top speed prop thanks
Spidybot
Re: prop numbers
The ol' props ID is on the forward end of the props hub so when you remove the prop, it'll be visible.<br /><br />Best guess so far would be a 17" pitch prop. <br /><br />Still, the other info is important to point out the right one.
