Prop Nut Kit
bighermHK45
Can someone help find the correct prop nut kit to include thrust washer for my 115 HP? Serial number is: 0G896605
I am not finding any resources that clearly state a part number for my outboard.
Ayuh,.... The prop nut is the typical Merc 3/4" prop nut, same as all the big outboards, 'n sterndrives use,...
The thrust hub, has to match the prop,....
wired247
Yeah. Youre going about it the wrong way. Serial number won't do you any good. You've got 50 or so different prop/washer/ratiner/hub configuration. Few of which matter to the prop shaft. What kind of prop are you using?
bighermHK45
It's a Quicksilver Prop 14x13P part number 48-77340A40.
