prop nut torque
allen.wood
I was wondering how tight the prop nut should be on a pin driven prop. Just wondering as should it be snug or very tight.
rrhodes
Re: prop nut torque
Each manufacturer has different specs. We need make, model and year specs to help.
allen.wood
Re: prop nut torque
its a Johnson 25r70 (1970 25 hp) to get the cotter pin in it can either be snug or I can turn it one more turn to get the pin in and thats about it.
kenmyfam
Re: prop nut torque
What I do.
Finger tighten the prop nut and then tighten just enough to get the pin in.
I have not lost one yet !!! (touch wood)
capped
Re: prop nut torque
I just bought a turning post rascal and it recommends 30ft-lbs or refer to the engine manual(03 25hp mercury). Dont know if this helps but figured i'd throw it out there.
southtexas
Re: prop nut torque
Gently like a spark plug...just tight enough to get the pin in.
