prop nut
Troy Adams
Hey! I've got another simple question for yoose guys!😏 I ordered a replacement prop nut kit from Sierra marine, I thought fr their description it would work. Well, I was wrong. The threads seem to be too course. How do I find a part number or something to get the correct nut. The out drive is an 84 800 OMC. Thanks
southkogs
Welcome aboard Troy.
Part number should be 032056 and is available HERE.
Somewhere in your engine there should be a tag that gives you an ID on the system (mine is on the rear engine mount , port side). That ID number (mine reads JUFM-10S) will give you the specific unit you're looking at and you can double check that part number.
