Prop options for 1981 Johnson 75hp
This year I acquired my father's 1981 Skeeter with a 75hp Johnson Seahorse. Now that the engine is working properly, my issue now is the prop. I've used both that he gave me. One is a 13 1/4" 17 pitch aluminum prop, which has great hole-shot, but I max out at 26mph at 5500 rpm. The other is a 12 3/4" 21 pitch SS prop that has zero hole-shot but top-end speed is closer to 40mph @ 5500rpm. I would like to get somewhere in the middle. My father claims that the 21 pitch was "shaved down" so that it could work on the engine.
I would like to stick with an aluminum prop to help with rpms for the hole-shot, but every prop I see on the prop guide for this engine is a 12" with 17 pitch. Does anyone have any recommendations to find this middle ground? I would hate to just start buying props, only to return them because they would not fit
Sea Rider
Check Iboats parts, accesories, props, should have some for that OB...
Happy Boating
