Bob Kimber
- Jun 13, 2002
- 97
Hi all,<br /><br />2000 model 90hp Merc, 60hrs running, recommended WOT 5000 - 5500rpm, boat is 17ft fibreglass half cabin estimated weight 2,600lbs normal load.<br /><br />I have been running 13-3/4" x 15" S/S prop from previous motor, inline six Merc, 36mph @5700rpm WOT, in the last 10hrs running WOT has slowly increased to 6200 rpm, tach calibration has been checked and is OK. Borrowed 16" pitch S/S prop and reached 6000rpm at WOT.<br /><br />Tried 19" pitch aluminium prop today, 32mph @ 4600rpm and WOT of 39mph @ 5200rpm, boat came up on plane well and accelerated smoothly to WOT of 5200rpm (normal load for test), generally performed well at all speeds including idle. <br /><br />Alternatives :-<br /> # keep 19" pitch prop, motor is within WOT recommended range and may free up a little more with more hours running?<br /><br /> # swap prop for 17" pitch with possible WOT exceeding recommended rpm range (5700 or higher)?<br /><br />Any comment would be welcome<br /><br />thanks Bob
