I have a 2000 2 stroke Johnson 70 hp on a 17 foot center console Wellcraft. Wide open throttle only gets me to 3500 RPM and it only pushes the boat around 16 mph. The prop that is on it now is a 13 3/4 x 15. I have no idea if this is even close to being the right prop for this set up because the motor came off of a work boat. Don't know if I need to increase or decrease the pitch or diameter of the prop. I conducted a compression test on all cylinders and it was perfect. Also tested spark one each spark plug and that is also good
