Re: Prop Pitch !! Help
No way we can say. If you are under-propped now, then it may be a slight improvement. There is very little difference in the 2 props. If your are propped just right or over-propped now, then you will lose some performance. Your coughing at idle is caused by running lean. try adjusting your idle needle out some.
