Little 16' Xpress H50 with Yamaha 50 hp 2 stroke I bought has an 11"D x 15"P stainless prop, that has been cupped a little and worked on some, so there is actually no real way to tell what it actually is any more. Motor will only turn 4500rpm with my son and I (thats an easy 500 lbs!), 3 big batteries in back, and no water in livewell. Motor should run 5500 RPM, I would like to get there with just my son (240), so I looking to get another 800 - 900 RPM. Rule of thumb is 200 RPM per inch of pitch, which says I need and 11" pitch prop. My question is really more about the "rule of thumb". If I am trying to change RPM this much, is it still pretty accurate? Most of the calculators I have used are steering me toward a 12"P. Would be nice to get it right the first time if possible...
Also, want to keep porpoising to a minimum. It is OK now, but I think some props will add bow lift and I know this little boat is pretty notorious for porpoising. Do you think I will have more of a problem if I get the boat to the correct RPM by changing props?
Thanks!!
Thanks!!
