Johny25
- Feb 8, 2012
- 265
Ok my boat is a 14ft Lowe V hull with an 88' 30hp Johnson. I tested 3 props with my new Tiny Tach today and here are my results. I run with what I will call a heavy load 25% of the time and a light load 75% of the time. When the wife and second son go out with us is the heavy load, about 250 lbs heavier than the light load (that includes the 2 extra seats I have to put in the boat). Engine specs are 5200-5800 RPM at WOT.
10X13 aluminum OMC prop
Heavy load (gross weight 1,150 lbs) =5450 RPM at WOT
Light load (gross weight 900lbs) = 5700 RPM at WOT
10.5X11 aluminum OMC prop
Heavy load =6010 RPM at WOT
(didn't even bother with light load due to high RPM at heavy)
10.13X11 stainless steel Cabela's (brand new ugh...)
Heavy load =6290 RPM at WOT
(didn't bother with light load again)
Yeah I am bummed that the new SS prop is not gonna work at all. Have to sell it now, or trade it hopefully since my return time has expired. Not even 30 minutes on the prop
. So I want a stainless prop because the stainless had much better performance characteristics than the aluminum. I know some say it doesn't matter with HP like this but I will disagree from what I saw and felt first hand.
So the question I have is since the same pitch SS prop ran almost 300 RPM higher than the aluminum prop could I actually push a 15 pitch stainless and be about 5500 RPM with a heavy load? Or should I go with the 14 pitch? I do not want to buy another $175-200 dollar prop that either over revs or under revs lol.
Cabela's does not have anymore props that fit my motor either so I am looking at a Solas stainless prop now. Does anyone own these and are they as good of quality as the Cabela's high performance props?
