Hello
Can anybody tell me that if you change the pitch of your prop, would it effect your gas consumption? I guess I'm trying to relate it to rear end differential gears in a truck. If your towing something with a higher gear, it gives you extra torque as well as increase your fuel mileage at lower speeds but you end up losing MPH. Where if you use a smaller gear you gain MPH but end up losing torque and use more gas during towing at the same speed. If that makes any since. Please any info would help.
Thank you
Thank you
