I have 17' runabout, with an 85hp Mercury Outboard, Im running a 17degree pitch, 3 blade, aluminum prop at 6000' elevation, I am having trouble getting on plane. What pitch do you reccomend, Do i also need to buy a new hub, does that come with new props?<br /><br />Do different brand props for my motor require different brand hubs or is it inter-changeable<br /><br />I used to run about 5000rpm at WOT, when lower unit was replaced, so was the prop, now I only get about 3800rpm, not sure what the orginal prop pitch was?<br /><br />Thanks
