Re: Prop Pitch ?
Mr Stony,
My '94 Mariner sales brochure says that the 3 cyl 90 (assuming the same as '93) is rated for WOT of 5500 rpm's. Also says that the gearbox is 2.3:1.
If you are happy with your current setup; boat speed, handling, engine noise, performance, and fuel economy, leave it alone. Just because you choose to run at 4000 doesn't necessarily mean you are hurting anything......and by your comments, you are indicating that you have a lot of whoopie left in the engine when putting along at 4000.
A 15p on that engine is not much prop (pitch). Now if the gearbox were 2:1 like a lot of higher hp Mercs then you might be pushing it; but I really doubt that too.....depends on the boat and load).
If you really want to know where you are, find a nice smooth spot on the water, with no one around (or any other thing that bothers you ) and put the pedal to the metal trimming the engine for max WOT speed. Come back with the rpm number (you can slow back down after you get it....grin) and we'll talk some more. I'm going to bet you will be up around 6000 or so. Wouldn't rev much over 6000 if it wants it. Once you hit 5500 you passed the test with your current rig.
Anything right at 5500 is perfect, a little over ok too. Now if you can't get to but 5000 then you might want to change something; but I doubt it......doubt that 5k is as high as you will go.
Let us know.
Mark
