imported_Briano
- Jul 4, 2006
- 6
Hi Everyone,
I have a 1987 50hp Force attached to a 14 foot Bayliner Bass boat. I just had my friend, a boat Mechanic, put in a new head gasket among other things.
The motor runs great now, but it seems that the boat should have a bit more get up and go. We have adjusted the motor angle to where it planes out the best we could get it. It is still a bit slow to plane out though, and in rought water, it was tough to get it to plane
I dont have a Tach, and my friend said that it sounds like the motor is running about 4000 RPM.... A bit lower then it should be. The current prop on it is a 13 1/2 pitch prop, and he suggested going with a 11 1/2 to bring the RPM's to where they should be.
Now, my first question is, does anyone else out there have experience with this setup? A 14 foot bayliner and a 50 HP Force motor? I am just curious what size prop you found to be best.
Secondly, can anyone else think of anything that would cause this? Compression is good, it runs about 144 degrees on each cylinder, and it idles nice and smooth, so everything with the motor appears good. He said a lower pitch should be the next step to get everything in order.
Any opinions or ideas?
Thanks!
Thanks!
