Prop problems on 55 hp johnson
JoeP.
Hello everybody, <br /> I got a question. How do you tell when a prop is bad. Is there a test you can preform without putting the boat in the water? <br />Thanks in advance, <br />Joe
Bob_VT
Re: Prop problems on 55 hp johnson
Inspect the prop. Look for tears in the metal, are all the blades even? Inspect the rubber housing...if it is bad it is normally torn.<br /><br />Bob
