Jake Swift
- May 23, 2012
- 11
Hi Everyone,
I am new to boating and wanted to upgrade my prop.
I have a 16 ft Swiftsure Ski boat with a 1979 Johnson 85 hp 2 stroke (Boat and motor weigh approx 1500 lbs).
With the OMC painted stainless steel prop (13 3/8 x 17") I was getting (on GPS) 38 mph peak (avg about 33 mph) at WOT 4900 RPM.
I purchased a Stiletto Advantage Stainless Steel with the guardian hub from iboats in a 13 1/4 x 17". With the same load in the boat I peaked at 40 mph (avg 36 mph) but at WOT 4400 rpm. Is this a normal drop in rpm without changing the pitch???? Is this RPM out of range for my engine (cause problems?)
With a decent load in the boat the WOT dropped to approx 4200 rpm. Another thing was that at WOT and trimmed up for speed the boat wanted to yaw to the left really hard. Is this normal??
Thanks for the help,
Jake
Jake
