answered prayer
- Jul 3, 2001
- 27
Is the prop supposed to move on the hub at all ?? I have a 125 hp force motor. Just out of curiosity ,<br />I scribed a line on the hub and the prop casting to check and see if it moves at all. Took the boat out with 5 adults in its.<br />I hit the throttle, and it takes off pretty quick considering the load. Planes up pretty easy.When I got it out of the water,checked the prop and<br />discovered the prop had turned on the hub somewhat.I didnt seem like it was slipping is this normal??.If it is slipping, does that mean if I got it rehubed,<br />it would work even better??<br />Thanks
