My 20' is planing at 22mph and is at 4500 rpm at 31mph which seems slow. What prop should I use? It has lots of low end power but shouldnt it run faster than this?
Depending on what type hull it is and the weight it could be OK. Or it could be horrible. Do you know the gear ratio of the drive? If we knew that and the pitch of the prop we could figure the slip percentage. That will tell us where we're at.
