I have a 1982 4cyl volvo penta 270 bayliner capri 19' boat. I had run over some small rocks in the water and it has taken off some of the aluminum off the properler blades - I have 3 blades - one of the blades has some of the edge missing (approx 1/2 inch) on the blade and I didnt think I hit the rocks so bad but apparently I did. The boat runs fine otherwise and I seen no other signs of damage but has lost some of its get up and go and speed. The propeller has been removed and I have a spare at home. The markings or specs on the props are mostly the same on both of them but there is a 301 on one prop and 401 on the other prop (I think) or its a 201. I am at work and I cant remember one or the other - I will know when I get home to see it again. I noticed all the other markings are the same and the numbers are all the same on both props besides that 301 and 401 thing. I dont know what that means. The boat when I bought it came with a spare propelor so I am hoping to use this one instead and have the damaged one reapired for a spare. Does anyone know what those markings are? Thanks for your assistance.
