Prop Question
banchigu
I have a 16.5 Aluminum Bass Tracker 1983 model and I recently put a Evinrude 50 HP engine on it, a 1974 big lower unit one (Model 50ESL74M). It had a Solas 2411-13.5-15 prop and it was not really doing much with a top speed of 25mph with a tail wind. Today a buddy gave me a stainless 13x19 prop and it did much better and it actually hit 28 mph for a second and held steady at 27 mph on a windless bank with just me on it.
It this good, average, or would a 17 or 18 pitch prop do better?
A million thanks in advance.
alldodge
We would need to know what rpm are you reaching
steelespike
You need to fit a prop that lets the motor operate within its wot (wide open throttle) rpm range.4500-5500.
Needs to be propped close to the max.for best all around performance.
To low or to high wot rpm will cause poor performance
and premature motor problems.You need a working tach and a gps for speed.An induction tach will work if properly installed.
Throwing on props is like russian roulette with a bullet in every chamber.
Not sure what your gear ratio is but it is possible the 19 is right.
We need to know your ratio. Pull the plugs and rotate the motor by hand count the motor revolutions for one prop rotation.
banchigu
Wow, I learned so much from you two (no sarchasm there) I am off to get a tach. And check the prop rotation...
