Prop repair
Fairclab
I was wanting to know i got a spun prop that the hub was pressed in... I pressed the hub out i was wondering if i could put a rbx interchangeable hub back in it without doing another pressed hub
are you sure the hub was pressed in and not bonded. if its a pressed in hub, it must be of same type that was in there.
99yam40
not many people have the proper equipment to press hubs in and out of props
prop is different for drop in hub than press in
